Academic Hardware Products (myDAQ, myRIO)
Using two myRIO
Dear All,
I want to use two myRIOs in the same project and share data between them and the host. How can I set the two myRIOs inside the project. Also, do I need to have two targets in the project?
(3,104 Views)
Hey,
Yes, you must create both myRIOs as separate targets in your project in order to develop and deploy for them. To add these targets, follow the steps here:
http://zone.ni.com/reference/en-XX/help/370622N-01/lvrtconcepts/adding_targets_project_rt/
As long as the devices are connected you should be able to find them automatically. You can also add them before they are connected, but you will need to be sure of the model number before you do so, as this ensures that the configuration you set can be deployed to the myRIO correctly.
Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(3,031 Views)
