Academic Hardware Products (myDAQ, myRIO)
Vision assistant
how do i download the vission assistant software?  I am pretty sure its part of the academic licence i am using
(15,113 Views)
You can download the NI Vision Development Module here.
Download the evaluation version and activate it with your academic site license.
Best Regards
Bruno
Bruno Noronha
Certified LabVIEW Associate Developer
Using LabVIEW 8.6
(15,104 Views)
Thanks, I realized the issue was with the fact that I'm running the software on a mac os, so apparently that portion of the software isn't available for a mac. I'm pretty sure this is my issue.
(15,101 Views)
That is correct. Vision Development Module is not supported on a Mac OS.
Vince M
(15,075 Views)
Is "Vision Assistant" actualy a module of "NI Vision Development" ?
(13,959 Views)
Yes, Vision Assistant is a component installed with the NI Vision Development Module (VDM).  It allows you to access the VDM functions and build an image analysis script in a separate program that can be converted to LabVIEW, C, or .NET code.  The product page linked earlier doesn't give a lot of detail on Vision Assistant but does briefly mention it.
Alex Person
NI-RIO Product Support Engineer
(13,941 Views)
