Academic Hardware Products (myDAQ, myRIO)
Where to buy 20 pin PCB connector for myDAQ?
Does anyone manufacture PCB connectors which fits the myDAQ?
Message 1 of 10
(10,107 Views)
Isn't the beauty of a PCB that you can print it to do as you please?
What kind of connector do you want specifically?
Message 2 of 10
(10,067 Views)
Of course the beauty of PCB is that we can design circuits however we want. The question: does anybody know where to by the 20pin connector that fits the myDAQ?  Thus, that is the connector I need.....
Message 3 of 10
(10,062 Views)
Sweet.  So we were supposed to guess you wanted a second connector for the myDAQ instead of being uncertain if you wanted a way to interface with your external PCB.  Now that we've read your mind, we can search the NI page and find: http://sine.ni.com/nips/cds/view/p/lang/en/nid/210731
Message 4 of 10
(10,057 Views)
Please Sir, nothing that has been written here deserves the condescending tone of your last reply.
The connector that is shipped with the myDAQ is not mountable on a PC board. Thus, it is not a PCB Connector. A PCB Connector for the myDAQ would be a connector that fits into the the myDAQ and could be soldered onto a PCB.
Message 5 of 10
(10,055 Views)
The connector is shown in the following picture 10705-01.jpg on the left-hand side. The long green connector!
Message 6 of 10
(10,052 Views)
When you're condescending after not getting a direct answer to your open-ended question, don't be surprised when you receive the same in return.
It would be relatively easy to solder the connection that comes with it to a PCB board.
Have you tried the part Spark says they use?
Message 7 of 10
(10,043 Views)
I beg to differ. I was not being condescending. I was asking a question. But I am glad to see that you admit to being condescending.
I beg to differ. The connector that ships with the myDAQ is not for soldering, but rather to fasten wires by screws.
I do not know which part you are referring to, but I feel I am getting closer to the answer of my question...
Message 8 of 10
(10,040 Views)
Accepted by topic author jetlund
Hello everyone,
To get back on topic.
Where you looking for this information?
https://forums.ni.com/t5/Example-Code/miniSystems-myDAQ-PCB-Connector/ta-p/3508182
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 9 of 10
(10,026 Views)
ThiCop: Thank you! Exactly what I needed!
Message 10 of 10
(10,023 Views)
