Academic Hardware Products (myDAQ, myRIO)
Why can i not get elvis DIO to turn on an LED?
 I have been tring to bypass elvis and have my DAQ (USB-6251) write directly to the ELVIS DIO pins (I want to be able to write fastr than ELVIS alows).  I an so far unsuccesful.  So I thaoght I would try a digital write using the DIO writer and reader.  This works fine, the DO pin can write to a DI pin and ELVIS is happy.  But when I connect the DO to an LED it will not light.  When I measure the voltage with the ELVIS DMM the voltage measured is only mV and not the expected 5volts.  The ELVIS DI reader will see a high level DO but as soon as I connect the DMM the DO sees a low voltage level.
(6,454 Views)
I just discovered that all grounds are not the same.  I had been using the power supply ground for the voltage reading, use the ground on the RHS and all seems to work
PCM
(6,449 Views)
