Academic Hardware Products (myDAQ, myRIO)
can i do this with ni myRIO or ni labview RIO evaluation kit?
my aim is to create a project using a labview product and labview software.
so in order to do it, my equirements are..
--> a stand alone device which can take real time ecg signals
--> after taking inputs, it shoud process the input signal and atlast
--> the result should be displayed in an lcd display.
this all in a stand alone device..
i have both myrio and labview rio evaluation kit.
and can these both devices support bio-medical tool kit VIs?
please reply,
thanks in advance,
Mayank
(5,261 Views)
Hi
You can do what you want using myRIO:
1. you can build a code and deploy it to the RT system and thus standalone
2. You can take ECG signals if the sensor that you are using has outputs that can be read by myrio
3. The results can be displayed on an LCD that uses I2C/SPI/ or UART
Good Luck.
AA
(5,257 Views)
hey li,
i have9attached pics)  these devices na d lcd too, and i think i does support all three modes.. but with some interfacing devices or tools, so can u say me which mode will be best and what all will i need to iterface lcd with myrio, other than lcd..
thakyou
(5,251 Views)
Download the project from the discussion below
http://forums.ni.com/t5/LabVIEW/myrio-lcd-i2c/td-p/3246146
The project is made to interface with an LCD using I2C protocol.
(5,244 Views)
hey li
   Sorry to bother u again the components used are not so clear in those pics , can you tell me all the components that are interfaced with lcd using myrio.
  thanks
(5,161 Views)
I am using hardware configuration similar to the components at this link.
(5,159 Views)
