Academic Hardware Products (myDAQ, myRIO)
digital output myRIO
I made a small project using the ExpressVI's of the Digital Outputs of the myRIO.
Everytime I want to execute the program ( send it from my laptop to the myRIO) all the DO's are set. Is there a way to make it standard that all the DO's are false when the myRIO does a start-up?
thanks
Lars
(8,587 Views)
When a bitfile is sent to the FPGA, all of the lines are tri-stated. If you want the lines to read false, I would recommend using a pull-down resistor on those lines. That way, when the lines are tri-stated, the DO lines get pulled to a '0'.
Best,
Tannerite
(8,584 Views)
For more specific info check out the myRIO Specifications.
On the MXP ports DIO 0-13 have a 40K pull up resistor to 3.3v.  DIO 14 and 15 have 2.2K pull ups resistors to 3.3v.
On the MXP port all DIO lines have a 40K pull down to ground.
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(8,573 Views)
What would the circuit diagram for that look like?
(6,645 Views)
In your program add a intilize case for Set all the DO states false. So when you run the Code all the DO.s From my RIO Should Be in OFF state
LabVIEW Developer
Happy to Wire
(6,619 Views)
Hi Kristoff,
I want to pull up my MXP port A and B. Can I do it programmatically? if not then what else I can do?
(1,702 Views)
