Academic Hardware Products (myDAQ, myRIO)
facing error in interfacing of ITG3200/ADXL345 6DOF with myRIO and labview
Dear Sir,
I am using myRIO to interface the ADXL345 link:http://www.hobbytronics.co.uk/imu-digital-combo-board   with the NI labview 2014 32bit. I have downloaded the IMU VI  from the following video link https://www.youtube.com/watch?v=-_GWEsrfxU4 . I did all connections and registers initializations of IMU with myRIO by following the video link. when i run the VI then a following error is appeared "Error-363011 occured at myRIO v1.0 Write I2C.vi". I also tried after adding/removing external pullups . Please help me to fix this problem. I have also attached the snap shot of register initialization part of my VI in this post for your more considerations.
(4,774 Views)
I would do a verification that all of the power grounding is done correctly.  You might need to ground the IMU to the low side of the myRIO ground.
Kelli Kravetz
Product Marketing Manager
LabVIEW, LabVIEW NXG, LabWindows/CVI, Measurement Studio
(4,755 Views)
ikeli, even I am getting the same error when I try to execute the vi with an ADXL345. Can you please suggest if we have to change the register values...? coz the main.vi works perfectly for the accelerometer supplied in the mechatronics kit.
(3,230 Views)
Hi Manojuk,
This forum post is 2 years old, according to the forum rules you should make a new forum discussion so you can get more view traffic from members of the forum community
(3,216 Views)
