Academic Hardware Products (myDAQ, myRIO)
how to run a saved vi in myrio
hi..
we are using a student version of labview .In that only two features have got license(labview development system and application builder).
actually we are trying to dump a VI file which we have developed for text to speech conversion on to myrio board and play the audio output.So please let us know about the software tools required , the interface procedure ,configuration of audio out of myrio board.
Thanks in advance...
(3,518 Views)
For required software, you'll need LabVIEW, the Real Time Module, and the myRIO Toolkit.
https://www.ni.com/en/support/documentation/supplemental/13/required-and-optional-software-to-progra...
Basically just add the myRIO to your LabVIEW project (https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/adding-rt-targets-to-a-labview-pr...) add a new VI under the target, and then whenever you run the VI it will deploy code and run it on the myRIO. You can pretty easily interact with the I/O using the express VIs which you will see after adding the device to your target. I would recommend taking a look at some of the example code like the link shows.
(3,485 Views)
