Academic Hardware Products (myDAQ, myRIO)
if statement in labview
Ok I am using labview 8.5. A little confuse. Can anyone give me a sample code that do the following?
if detect digital input from port 0 line 1 from DAQ
wait 100ms
send digital output to port 0 line 2 to DAQ
(6,729 Views)
Maybe like this...
(6,717 Views)
For some reason I can't view your file. I have labview 2013 but when I try to open it, the browning window keep popping up as if I need to point it to some specific location \National Instruments\LabVIEW 2011\instr.lib\Agilent 34401\Public\Utility
(6,703 Views)
Hi for some reason I cannot open that file. It keep asking me to browse to a window or something. Can you rewrite that simple code in labview 2011? I just installed by labview 2013 and it seems to be a problem.
(6,689 Views)
Hello Hunkeelin,
I downloaded the DIO.vi that was posted here and saved it for LabVIEW 2011, I hope you are able to open it now.
Matthew R.
Field Applications & Systems Engineer
(6,680 Views)
