Academic Hardware Products (myDAQ, myRIO)
moving message
hi
is it possible in labview 7x .   in a vi at certen point when buton is pressed (true)then a messag (string ) apear  in motion (mean falasing or moving randomly or )
(6,377 Views)
Or 'what'? And what is 'falasing'? If you want to move it arrund on just the front panel of a VI, the you can right click on a string indicator and select 'Create Property'. Go to the diagram and right click on the property and select 'Change All to Write'. Right click on it again and select Properties>Position>All Elements. Right click on the input of the property and select 'Create Control'. You now have a front panel control that determines the position of the string indicator. Experiment with that. There are a lot of other things yiou can do with a property node such as make the string indicator blink, change the font size, text color, etc. You need to be more clear on exactly what you what to do.
(6,371 Views)
