Academic Hardware Products (myDAQ, myRIO)
myRIO + myDAQ = Elvis?
I looked for articles on the forum but I don't know if it makes sense. I have MyRIO-1900 + myDigital from Digilent. I was thinking about buying myDAQ but I've read a lot about Elvis II+ recently. If you have myRIO, does it make sense to invest in Elvis or will myDAQ be a suitable supplement? I use LabView mainly as a hobby (I also have Mindstorms, PLC and several smaller ESP32, Arduin and raspberry boards).
I don't want to duplicate solutions. Does elvis have more to offer than myDAQ and myRIO?
(1,973 Views)
I would say "no".  What do you want to do?  If you want a relatively-inexpensive USB-powered multi-function device, the myDAQ, though limited, isn't bad.  If you want to get into LabVIEW Real-Time or FPGA, it is hard to beat the myRIO (though it is harder to set up, and requires external power (more than a simple USB connection).  I have experience with both.  I have no recent experience with the Elvis, except to say that a sly NI sales rep managed to convince our Engineering Department to purchase a dozen Elvis I instruments for a "student lab" the same year that the Elvis I was replaced by the Elvis II (and now there is an Elvis III).  These were never used -- we replaced them with USB 6009s for much lower cost and much greater utility.  So I may be biased ...
Bob Schor
(1,822 Views)
