Academic Hardware Products (myDAQ, myRIO)
myRIO sampling rate
I'm using myRIO for data acquire, I'm actually acquiring data from 8 channels (AI). But the velocity of the data acquisition it's not constant. How can I set a constant sample rate?
(3,532 Views)
Hello prs88,
Firts of all  you have to ensure that your timed loop is running as you determined. For that you can put an indicator on the left data node on the timed loop. Second of all I advice you to not use Express VIs inside the RT. Try to use low level functions
César Teixeira
Certified LabVIEW Developer - CLD
Applications Engineering
National Instruments Brazil
(3,458 Views)
Obrigado pelo retorno!
Alterei o código para as funções de baixo nível conforme indicado nesse link, porém o tempo continua maior que o esperado, na verdade, até aumentou.
Você teria algum exemplo para me mostrar de como fazer essa leitura?
Preciso fazer a leitura em oito canais analógicos, teoricamente, poderia realizar essa leitura a uma taxa de 62,5KS/s, estou utilizando uma taxa de 2,5KS/s e não está funcionando.
(3,449 Views)
Hi prs88,
You can find some examples about this kind of acquiring on: LabVIEW>Find Examples> NI 9215 Getting Started.lvproj. This no exactly an example for myRIO, but can give you some ideias about how to do it. The only changes you will need to make is to point on VI to your myRIO target instead of cRIO target
César Teixeira
(3,367 Views)
