Academic Hardware Products (myDAQ, myRIO)
myRIO strong bump when playing audio with High Throughput Audio Out low level VIs
I already posted this question almost a month ago but no one seemed to know the answer:
http://forums.ni.com/t5/Academic-Hardware-Products-ELVIS/myRIO-Audio-Out-annoying-start-and-end-puls...
, so I will try again because it is a problem I need to solve somehow...though it doesn't seem to have an easy solution.
Everytime I play an array of samples with the low-level VIs from the myRIO Hight Throughput Audio Out palette, I hear a strong noise at the start and at the end of the sound, and I know for sure that  these loud samples are not within my array, they are generated and added to my audio by the myRIO. They are so loud that I can't ignore them. You can see what I mean on the pictures I provided in the other thread, with more information too.
Every help would be much appreciated.
Thank you,
Seitseman
Message 1 of 1
(3,622 Views)
