Academic Hardware Products (myDAQ, myRIO)
mydaq does not recognized max
Hi. When I open the Daq Assistant on Lab View it gives me a "No supported devices found" message, the labView works just fine but it does not recognized the myDaq. And before It did worked, What can I do?
(6,237 Views)
Have you installed ELVISmx driver, https://www.ni.com/en/support/downloads/drivers/download.ni-elvismx.html, which is needed for myDAQ?
(6,225 Views)
I did installed the driver and it worked for a while, however, when i opened it the day after it did not recognized it again.
(6,220 Views)
If you are using Measurement & Automation Explorer 5.0 or later, you could try resetting your configuration data by clicking the following menu option. It may solve your issue if MAX has been corrupted. Just a note, resetting your configuration data will clear any saved devices/scales you have.
Reset Configuration Data Utility
Also, what operating system are you running?
Ian K.
Software Developer
Data Ahead AG
(6,211 Views)
