Academic Hardware Products (myDAQ, myRIO)
myrio & DAQmx
I am new to the MyRIO system, and have a quick question about analog data acquisition.  Can the DAQmx VIs be used with the MyRIO?  In my experience, when I use the DAQassitant to try to select an input device, the MyRIO does not show up.
Thank you very much,
Sean
(7,250 Views)
Hi seanmw,
DAQmx VIs will not work for myRIO because it runs off the NI-RIO Driver.  There is a myRIO Module that comes with myRIO.  Here are pages to the module and the VIs that you will be able to utilize:
http://zone.ni.com/reference/en-XX/help/373925A-01/myriohelp/myriohelp/
http://zone.ni.com/reference/en-XX/help/373925A-01/myrioreference/myrioreference/
Peter T
(7,224 Views)
Thanks for the reply Peter, I apprecaite it.
(7,218 Views)
