Academic Hardware Products (myDAQ, myRIO)
ni-daqmx using vb6
Hi
iam trying to connect ni-daqmx to vb6 and here is my code.
 Sub temp1()
Dim mytask As Long
Dim Data(1000) As Double
DAQmxErrChk DAQmxLoadTask("temp1", mytask)
DAQmxErrChk DAQmxReadAnalogF64(mytask, 1000, 10, DAQmx_Val_GroupByChannel, Data(0), 1000, 1000, ByVal &O0)
Text14.Text = Data(1) ' for displaying data in textbox
Text14.Text = Format(Text14.Text, "#00.00") ' making 2decimal digit
DAQmxErrChk DAQmxStopTask(mytask)
DAQmxErrChk DAQmxClearTask(mytask)
Exit Sub
errorhandler:
DAQmxStopTask mytask
DAQmxClearTask mytask
MsgBox Err.Description
End Sub
Private Sub cmd_acquire_Click()
Timer1.Enabled = True
Timer1.Interval = 60000 ' setting 1minute
End Sub
Private Sub Form_Load()
Timer1.Enabled = fasle
End Sub
Private Sub Timer1_Timer()
temp1
End Sub
like wise i have 8-10 task whih diplays the temperature value in text14 to text22
using timer iam calling this function for every 1 minute ,
iam getting data but as time progresses the data capture is getting delayed means initialy it will execute at 1minute
after say 1or two hours the capturing is getting delayed by 30-40 sec.
iam using scxi chasi with temperature module. using task iam calling in to my vb application.
iam unable ti figure out the route problem for time delay.
Regards
Raj
(6,608 Views)
Hey Raj,
Does the program run continously for 1 hour and then you experience the delay? Or is it just that the program sometimes takes 1 minute to capture everything it is suuposed to when it is run, and sometimes it takes more?
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(6,597 Views)
hi Sahil
the programme run continuosly for 2 1/2 hours ,
and the aquire is programmed for 1 minutes so every one minute the data refreshes .
initial within 2-3 minutes the data refreshes bang on time but as time progressses the data capture is adding delay
in geting data
after 30 minutes 6-8 sec delay
after 2 hours 25-30 sec
and at 21/2 hour there will be delay of 35-40 sec.
iam using scxi 1ith 1303 temperature module.
regards
raj
(6,591 Views)
Hello Raj,
Yes, so since the program runs continuously, and the Windows OS is not deterministic unlike Real-Time OS which is deterministic, the processor usage builds up and it slows down on continuous run of the LabVIEW application, so the time taken increases down the line. This kind of behaviour is expected and can not be avoided on the PC.
Sahil Singla
(6,588 Views)
Hi sahil
I know windows is not real time operating system, it has got some delay which will be interms of milisecond or seconds .
i have set the task (temp1) to n-sample mode not on continuos mode.
so task exectes @ 1 minute interval.
the task is working fine in Ni-daqmx.every time i run the datas are geting in no time.
iam calling these tasks in my vb6 application, there i have problem execution of task getting delayed as time passes.
Regards
raj
(6,586 Views)
