Academic Hardware Products (myDAQ, myRIO)
play a .wav file using myrio
i want to play  .wav audio file on myrio...my current program plays the .wav file on a pc..but i want to use the audio out  port on myrio to play it.....i need ideas on how to proceed further...
i tried changing the play waveform vi...but i was getting an error stating that sound file read simple vi doesnt work on myrio....
need help ASAP..
(6,418 Views)
I have the same doubt... I always get an error when opening the .wav file
I am using (/home/lvuser/....wav) this path.
The code is apparently correct because the arrow is not broken.. so I think i may have the wrong path.. But i have tried it in so many ways but with no succed.
Thank you so much for the help
(6,327 Views)
It looks like to me, MyRio doesn't directly play .wav file, you need to process it first on your PC to convert .wav into 2 arrays: left audio and right audio.
In the first figure, I simply read a wav file and save it into "data".
In the second figure, under "data" you will be able to find 2 arrays (the "Y" array), which correspond to left audio and right audio. Simply copy them and paste to a new vi under myrio.
In the third figure, use express VI "analogue output" and pick "audio out/left", "audio out/right", string two arrays into them, then myrio will be able to play!
Note since wav is not compressed, the arrays of a complete song will be very long, myrio has limited memory, so probably won't be able to play a complete song (about 1min maybe good).
(3,912 Views)
