Academic Hardware Products (myDAQ, myRIO)
plot analog signal fpga i/o from myRIO
I have been trying to aquire analog signal from fpga i/o from myRIO. I want to aquire analog signals from 4 channels but i am currently making the code for one channel only. I have made some code to aquire the sine input from the function generator, but i cant plot it. I used cluster and waveform graphs, but it gives error. Finally i attatched a FIFO block to store data. Now i need help in plotting the data. I have attached my vi . Pls help.
Thank you.
(4,719 Views)
Hi santamaria,
This example: https://decibel.ni.com/content/docs/DOC-4342
I think is close to what you are trying to accomplish, I would try using this and seeing if you are able to get the results you want, and then building off this a starting point.
In a more basic sense you're going to have to read the data from the FIFO, and then add a start time and delta t to the data in order to plot it. The actual plotting is typically done in a host VI, not on your FPGA target, like in the community example.
Hope this helps!
Selene
(4,693 Views)
That means, i will acquire the data on the FPGA target and then use the host VI for futher processing of the aquired data, right?
(4,688 Views)
Yup! This help document explains the process a little:
"Using a Host VI to Communicate with the FPGA Target (FPGA Module)"
zone.ni.com/reference/en-XX/help/371599H-01/lvfpgaconcepts/pfi_comm/
Selene
(4,676 Views)
