Academic Hardware Products (myDAQ, myRIO)
starter kit 2.0
I am having some trouble with the daNI starter kit 2.0 robot. It is not detected by MAX or anything else, does anyone else ecountered this problem?
Stefan
(6,013 Views)
Accepted by topic author N3utrin0
Hi Stefanb1
Usually, if a RIO device such as a compactRIO or sbRIO isn't appearing in MAX, there may be a few different reasons. Firstly, have you installed the NI-RIO drivers on to your PC? It's important that you've installed your software in the correct order, with the development suite first, then the extra modules and toolkits (such as the robotics toolkit) and finally, drivers (NI-RIO).
If you have installed your software in the correct order, please ensure the quality of your ethernet cable and connection.
ShalimarA | CLA
(5,993 Views)
