Academic Hardware Products (myDAQ, myRIO)
virtual elvis not connected error
I'm trying to make a simple circuit using virtual elvis with multisim.   I connect the circuit to the elvis +5V and ground.   When I switch to the 3D elvis breadboard mode, I connect all the parts and wires, but the connectivity test keeps telling me that
Multisim  -  2007-03-03 13:43:08
---Design Rule Check---
---0 Design Rule Errors Found---
---Connectivity Check---
Connectivity Error : For Net 0, Pin Ground2 of component ELVIS10 is not connected.
Connectivity Error : For Net 1, Pin 5V2 of component ELVIS10 is not connected.
---2 Connectivity Errors Found---
I can't figure out why.
(6,406 Views)
Do you have a physical Elvis board? Do the connections you have made work otherwise, in any other software? Is this error seen only in the 3D elvis breadboard mode? If this is only a multisim problem please post your question on the multisim forum.
Thank you,
Raajit L
Raajit L
(6,389 Views)
