Actor Framework Discussions
ACBR Proxy Caller/ Memory Leak problem
Drew.Rankin wrote:
AQ,
Yes, switching back to normal AF and the application levels out at 104MB. This was definitely not the case when Debug AF was used. Too bad there isn't an easy way to switch between the two versions.
Glad to hear your leak is just that.
I wish it were easier to do debugging also. That's something the community continues to work on. 😉
Message 31 of 31
(1,615 Views)
