Actor Framework Discussions
AF exe doesn't leave memory when exiting
Not sure, but I think that it will work just fine if you start a VI running using the Run VI method and have it invoke the Quit LabVIEW node. Not the Call By Reference node, but just wire a Static VI Reference to the Run VI method with FALSE wired to the terminal for whether to wait for it to finish. That subVI will then be running as a top-level VI on its own... and the only thing on its diagram would be the Quit LabVIEW node. I think that will work. Haven't tried it, but based on the description in the CAR, I think it will work.
After tomorrow, I'll be on vacation for two weeks. Ping user niACS if you need more AF help in that interval or post on the regular NI forums and get an AE to start a support ticket.
Message 11 of 12
(1,205 Views)
I tested the workaround and it doesn't seem to exit unless debugging is enabled. I started a new document here to discuss this bug and attach code.
Message 12 of 12
(1,205 Views)
