Actor Framework Discussions
About exe building
Hello,everyone, I have a problem about building exe, I make a little change to sample AF(just load Alpha Actor directly,please see attached picture and VI  for a detail), and it can load Alpha Actor normally in edit enviroment, but after building to exe, it can not act as development mode.  I think all necessary file and dependency have been included. maybe path problem? please make an explanation for me.
[This question has been answered.]
(5,369 Views)
This is the same problem that I had here. Set the "Open actor core front panel" input to False instead of True in AF_AF.lvlass:Load App.vi->Launch Actor.vi. That will probably solve the problem.
Good luck,
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
(4,204 Views)
Thanks, dsavir. with your help, I get deeper understanding about AF.
(4,204 Views)
You're welcome
― Terry Pratchett
(4,204 Views)
