Actor Framework Discussions
Actor Framework Executable Doesn't Run Root Actor
Is there a know work-around for this? The I'm having the same problem. My best solution is to check the "Show front panel when called" tick-box in VI properties for the root actor's core, but this results in the front panel opening twice in the executable (at least on Ubuntu).
Message 11 of 11
(42 Views)
