Actor Framework Discussions
BUG: VI unloads from subpanel when InsertedVI property is called from an asynchronous process
I just posted a bug over on the LabVIEW forum: https://forums.ni.com/t5/LabVIEW/BUG-VI-unloads-from-subpanel-when-InsertedVI-property-is-called/td-...
Cross-posting here because:
  1. The sample code is AF-based
  2. The bug is triggered by accessing subpanel properties from asynchronous code (like an actor), which can be common in AF projects
  3. You guys are smart, and may have some valuable input 😁
Message 1 of 1
(363 Views)
