Actor Framework Discussions
Building the Actor Framework to a lvlibp in LabVIEW 2017 crashes LabVIEW
I'm trying to re-architect a LabVIEW 2017 application based on the Actor Framework. I'd like to make some of my Actors into packed project libraries to make my main project smaller and the application more scalable.
But I run into an issue already on my very first step when I try to build a Actor Framework.lvlibp. LabVIEW keeps crashing and I can't build my packed project library.
I follow this guide:
1) Open LabVIEW 2017
2) Create a project (Actor Framework.lvproj)
3) Add the Actor Framework.lvlib to the project
4) Create a build specification (Packed Library)
5) Build
Right away the build just says Done but LabVIEW then hands and nothing is build.
I found the following thread mentioning this might be a bug in LabVIEW 2017:
https://forums.ni.com/t5/Actor-Framework-Discussions/AF-PPL-Plugin/td-p/3689366
I haven't been able to find a work-around. Does anyone know how to proceed? I guess this is a fairly normal operation?
Best Regards
Anders Rohde
CLA, CLED, CPI
(4,290 Views)
There had been a bug introduced in 2017 which has been fixed.
Users reported that building a PPL was possible again with the latest fix
Which version is your LV2017?
(4,266 Views)
I'm running on LabVIEW 17.0f2. Newest version of LabVIEW 2017.
I'd really like to avoid upgrading to LabVIEW 2017 SP1 to solve the issue. This project is complaint and under FDA so not just something you can just do. So hopefully someone knows a way around.
Br,
Anders
(4,258 Views)
Regarding these constraints... what are the reasons to use a PPL? Couldn't you go with source libraries?
It would at least save you from the trouble switching the development enviroment.
(4,254 Views)
Br,
Anders
Replace your LV 2017 AF Debug library (<labview>/resource/af debug) with the one in LV 2016.
The issue is not with the new version of the debug library itself, but a change in that library exposed a bug (described to me as "ancient") in the app builder.
(4,236 Views)
Awsome! Just what I needed
Thank you Allen 🙂
(4,228 Views)
