Actor Framework Discussions
Can message maker default directories be changed?
The message maker puts new messages in "<ActorName> Messages", but I'd like to put them in "Messages" most of the time.
I tried finding where the directory name is chosen, but I ran into a locked VI. Is there some place to change this?
I'm mostly keeping the following directory structure for my actors:
./<ActorName>/
./<ActorName>/<ActorName>.lvlib
./<ActorName>/Actor/
./<ActorName>/Actor/<ActorName>.lvclass
./<ActorName>/Actor/<MethodName0>.vi
./<ActorName>/Actor/<MethodName1>.vi
./<ActorName>/Messages/
./<ActorName>/Messages/<MethodName0> Msg/
./<ActorName>/Messages/<MethodName1> Msg/
Only for helper actors do I need more specific names
./<ActorName>/<HelperActorName>/
./<ActorName>/<HelperActorName>/<HelperActorName>.lvclass
./<ActorName>/<HelperActorName>/<HelperMethodName0>.vi
./<ActorName>/<HelperActorName> Messages/
./<ActorName>/<HelperActorName> Messages/<HelperMethodName0> Msg/
Even so, I'm thinking of keeping those helper actors in a different toplevel, so I can keep their pathnames short too.
(4,519 Views)
Look in the following directory and file.
Program Files (x86)/National Instruments/LabVIEW20xx/project/_Message Maker/support
Look at file name "Calculate Message Class Path.vi"
I am in no way stating that you should change this file, but you might want to look in here if you are looking to alter any of the directory structure of messages.
(4,271 Views)
Just an additional FYI, the solution I mentioned works in LabVIEW 2014. I dont know about LabVIEW 2016, as it appears that the message maker has been changed somewhat.
(4,223 Views)
@StevenHowell_XOM wrote:
... it appears that the message maker has been changed somewhat.
A little, yes.  Smiley Wink
But most of the changes wrap the old code, so that VI should still control the default message paths, if I recall correctly.  Just make sure you test all three message types!
(4,217 Views)
