Actor Framework Discussions
Can those queue references as stored in a caller be 'dynamic'
Elijah Kerry of NI provided an example of dynamic actors stored in lookup tables in his project called 'Measurement Utility (Plugin Hardware Abstraction Layer Using Actor Framework)' at
https://decibel.ni.com/content/docs/DOC-21441#/?page=5.
If one installs that project one gets more items in \user.lib\Common Components\, among is \Methods\Measurements Scan.vi, which scans a set of directories for class definitions *.lvclass and converts them into measurements-objects, which are stored in a lookup table of the caller object of type 'Controller'. Those objects are handled with Get_variant_attribute and Set_variant_attribute - the only problem is to get unique names.
The elegance of this solutionsis hard to explain with words.
Thank you all at NI!
Message 11 of 11
(1,107 Views)
