Actor Framework Discussions
Comparison of different frameworks
Anyone interested in doing an AF version of a sample project suggested by SachaE in the CLA forum?  It's for comparing different frameworks/styles of programming.  Steve Watts has done an LCOD version and I've done one with Messenger Library.
(5,757 Views)
Almost done...
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
(4,044 Views)
Unfortunately I am unathorized to see it, but curious to see what it is...
What is this sample project?
(4,044 Views)
Don't know the secret handshake?   It's actually an extremely minimal project, except that it requires dynamically calling multiple UIs that all interact with a central data store.   So it's intended to show how a framework does creation and interaction between code modules.  Perhaps Casey could post his version here?
Added later> Casey has posted it here.
(4,044 Views)
