Actor Framework Discussions
DVR or data copy? How to deal with large data in AOP projects
Try using "Preserve Run-time Class".  You can replace the object in the DVR with another of the same class or a child class.
Message 21 of 23
(1,182 Views)
Thanks.  Actually just stumbled upon that solution on an old LAVA thread.
Now to see if the performance improvements were worth it...
-John
Certified LabVIEW Architect
Message 22 of 23
(1,182 Views)
Just create a single-element cluster of your object and put that in the DVR.
DVRs of single-element clusters allow the type of the data within them to change because they disallow casting the refnum itself to other types. A reference archictecture can only support one or the other, never both (because otherwise you trivially get references to a child type that contains a type that isn't a child).
Message 23 of 23
(1,182 Views)
