Actor Framework Discussions
Error 1556
***FIXED*** I found my issue.
Good evening. I am seeing some peculiar behavior in my application that is built with Actor Framework.
I am using LV2014 SP1. In the middle of a test run, the process just stops. I check the error log and I see an error 1556, and it gives me the chain of callers.
 When I check the processes in question, there is a message sent from one actor to another, however, even though the error 1556 is given, the message is still received by the intended actor.
Not sure what is going on. The error causes my process to stop, though the message was received and handled, everything after the message was received is stopped from running.
Steven Howell
Controls and Instrumentation Engineer
Jacobs Technologies
NASA Johnson Space Center
Message 1 of 1
(4,588 Views)
