Actor Framework Discussions
Fan A and Fan B controls not included during a message build for a send message vi
Hi All
  • Using Hands On Actor Framework exercise page 33. I had no problems performing message builds for update pump and update temperature but when l performed a message build for update Fan the object would not include both Fan A and Fan B. So when l created the update Fan Status vi on page 35 both Fan wires would not connect to the Send Update Fan vi.
  • The image in the file illustrates the problem using an unbudle by name. I had to insert both Fan A and Fan B into the built "Send Update Fan vi".
  • The solution example clearly illustrates that the object should detect both fans during the message build.
  • Can anyone help me with the problem?
Regards
Wetland
(4,250 Views)
Hi Wetland,
The NI Community Hub is actually a location for questions/support on using the NI Community.
I have moved this post to the Actor Framework Community group where I think you will have a lot more luck getting this question question answere, once the Community members in that group have a chance to see it.
Good luck getting things working!
-Matt
Matt
NI Community Team
(3,259 Views)
