Actor Framework Discussions
How to build an Executable for an Actor Framework based project?
Hello All,
I took over an Actor Framework based project. The development works fine. However, when I try to build an Executable the build fails (fpsane error). I've scoured the forum and have performed most of the suggestions to no avail. I do not currently have an active NI tech support subscription. I've generated an Actor Framework.lvlibp added it to my project but build still crashes (when compiling my first lvclass). There are no broken VI (I've gone through the project and opened every single vi). I've read the failure logs but I don't know what it says. So my question is can someone point me to a document or video which shows (in detail) how to create an executable and deploy it.
Thanks.
(594 Views)
You're in a tough spot without a support contract because if the VIs are fine, it sounds like potentially like something weird with your specific installation.
Do you have another computer you can load the project on and see if anything is broken there? And if the code looks fine on the other computer, do you get the same build error?
CLA CLED AF Guild
(560 Views)
