Actor Framework Discussions
How to make Actors not shared clones or to "clean" the clones on start?
I think we're on the same page here, and I appreciate you sticking with me.
>then you write it with an input for first call
That's what I meant by "manually initialize", you're basically replacing the First call? primitive with a "manual" boolean input. I understand I'm not maintaining the whole actor'sstate.
My use-case is the third one you mentioned. Basically, if this wasn't a shared clone reentrant, I'd have had a First Call inside that VI to automatically refresh the display on first call even if the display state enum hadn't changed, then I wouldn't need to worry about wiring it up. Not that it's a big deal- it's not at all.
The only time this would be a minor pain is a hypothetical situation where I didn't know when a given subVI would be called the first time and still needed to initialize it; in that case I'd need to manually invoke it one extra time at the start of the Actor to initialize it, but it's not that big of a deal.
Message 21 of 22
(778 Views)
Yes, I think we're synched up now.
Summary for future readers: "First Call?" really does mean "first time this section of code is invoked application wide". You can use it for system resource acquisition and one-time computations of constants. For everything else, you need to know your current system state and pass that state into common functions that need to know it.
Message 22 of 22
(775 Views)
