Actor Framework Discussions
How to restore Actor Framework default project template ? (LV 2013)
Hi NI community !
So I was starting to learn how to create my own project templates and wanted to see how was the Actor Framework project template made.
I then had the bad idea to open directly the template files in LabVIEW 2013\ProjectTemplates\Source\Core\Actor Framework and mistakenly modified and saved the VI that does all the scripting tasks (PostCopyScripting.vi).
Now when I try to create a new project from this template, it crashes.
Is there a way to restore the default project templates as when LabVIEW is installed ?
Or is there any place where I can download the original project template for Actor Framework ?
Thanks for your help.
Raph.
Message 1 of 1
(3,038 Views)
