Actor Framework Discussions
LV2014 f2 patch released; likely to help AF users
The patch is described and downloadable here:
http://digital.ni.com/public.nsf/allkb/9769B60F824ECFB986257D41006CAA7D
One of the fixes is CAR 492898 "Open VI Reference can potentially hang on the second call."
There were people on the AF forums who reported problems with this. I believe the AF difficulties are resolved with this patch.
(6,036 Views)
thanks for the info, will try asap.
I'm currently debugging a larger AF application.
cheers
_________________________
CLA
(4,867 Views)
This update indeed (based on personal and customer tests) fixes hangs that could appear on some systems, but were impossible to reproduce on most other systems.
In this case I am referring to code that should perfectly work, not code that is written to hang. (some people do/try this )
Thanks AQ for working on this!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,867 Views)
Thanks a lot, this patch solved my problem. I just started developing small AF application in LV2014 and each time I stopped my application, the project library and LV remains locked.
This is more school project than large application, but I can send the code if someone want it.
(4,867 Views)
Sweet. I really expected that we had found and fixed it, but there's always that twinge of doubt until release.
I'm glad to hear the confirmations coming in.
(4,867 Views)
