Actor Framework Discussions
Launch Actor.vi is "X" mark....
Hello, I learning to actor framework design pattern.
I study Actor Framework Hands-on documents and open the exercise project.
When I open the some VI, Launch Actor.vi marked "X".
Although I can find the VI file in LabVIEW Project, the code doesn't seem to be executed as an X appears in VI.
Does anyone know about this issue?
I using LabVIEW 2020 and Wind 10.
I lookforward to your reply.
Thank you.
(1,928 Views)
Hi Jarvis,
The "X" indicates that the VI in question ("Launch Actor.vi") has been deprecated.
In more recent versions of LabVIEW (for a while now, but I guess not in the example) we're guided to instead use "Launch Root Actor" and "Launch Nested Actor", which are a little simpler and more clearly describe intent.
In this case, you can use Launch Root Actor and you won't need the Queue reference to be created separately.
GCentral
(1,925 Views)
To clarify, Launch Actor.vi is deprecated for production use.  It is still used to launch isolated actors as part of unit testing.
(1,901 Views)
