Actor Framework Discussions
Libraries loaded in Dependencies even when not called
I have an lvlib with VIs that use AF. I built it into a package, and set each vi, ctl, lvclass and the lvlib file to "locked, no password". All is well.
I started a new project, created some new actors that do not call the aforementioned lvlib files. However, the lvlibs are listed in dependencies. I am not able to tell why by viewing VI Heirarchy. I tried "Find Callers" on each VI and class in the lvlib (it's not large). A "Do.vi" shows "Actor Core.vi" as its caller. Mass compile and force recompile are not helping. It feels like it's time to recreate the project from scratch. Just in case - does anyone have any other linkage-tracking/fixing tricks?
(4,997 Views)
VIPM package, not ppl. It was a way to install the lvlib on a development machine.
(3,856 Views)
Ah, a "VI Package". To be fair, I thought the same thing as Oli.
Can you post a screenshot of your VI hierarchy to help us understand the problem?
(3,856 Views)
The heirarchy only showed that the lvlib (and its VIs) in question was under "My Computer". That means a project linkage, perhaps, so I opened the lvproj file in a text editor:
  <Item Name="Dependencies" Type="Dependencies">
   <Item Name="vi.lib" Type="Folder">
    <Item Name="Actor Framework.lvlib" Type="Library" URL="/&lt;vilib&gt;/ActorFramework/Actor Framework.lvlib"/>
    <Item Name="Error Cluster From Error Code.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Error Cluster From Error Code.vi"/>
    <Item Name="Reply Msg.lvclass" Type="LVClass" URL="/&lt;vilib&gt;/ActorFramework/Reply Msg/Reply Msg.lvclass"/>
    <Item Name="Clear Errors.vi" Type="VI" URL="/&lt;vilib&gt;/Utility/error.llb/Clear Errors.vi"/>
    <Item Name="Time-Delay Override Options.ctl" Type="VI" URL="/&lt;vilib&gt;/ActorFramework/Time-Delayed Send Message/Time-Delay Override Options.ctl"/>
    <Item Name="Time-Delayed Send Message Core.vi" Type="VI" URL="/&lt;vilib&gt;/ActorFramework/Time-Delayed Send Message/Time-Delayed Send Message Core.vi"/>
    <Item Name="Time-Delayed Send Message.vi" Type="VI" URL="/&lt;vilib&gt;/ActorFramework/Time-Delayed Send Message/Time-Delayed Send Message.vi"/>
   </Item>
   <Item Name="user.lib" Type="Folder">
    <Item Name="xxxx_CRC_CCITT.lvlib" Type="Library" URL="/&lt;userlib&gt;/xxxx Tools/CCITT/xxxx_CRC_CCITT.lvlib"/>
    <Item Name="xxxx_xxxxx Byte Parser.lvlib" Type="Library" URL="/&lt;userlib&gt;/xxxx Tools/xxxx Byte Parser/xxxx_xxxx Byte Parser.lvlib"/>
   </Item>
  </Item>
After deleting the "user.lib" entry and loading the project, the dependency was gone, and did not reappear after running code or mass-compiling.
However, I placed one of the VIs from the lvlib, then deleted it - and the lvlib is again listed in the dependencies.
(3,856 Views)
