Actor Framework Discussions
Performance question: AF message queues versus SVE
I have a deployed application (PXI based) that uses NSVs to populate bound UI front panel indicators from a separate background task which acquires the data from a MIL-STD-1553 bus controller (all on the local machine, not across a network). This is working well (eliminates code on the block diagram) even at update rates down to ~40 msecs although there were a couple of quirks I had to deal with. There is not a huge amount of data being passed with about 35 indicators in total, half of those being small arrays.
I have the opportunity to upgrade to LV 2014 (from 8.5) and clean up the application and I thought converting to AF would be appropriate since I have several QSMs in parallel threads. Should I stick with the NSVs or will I have at least the same performance (or better) using AF messages? I would think that the under the hood SVE uses message queues itself so my guess is that there is negligible difference in performance.
Bill M.
(3,351 Views)
Or perhaps even better, stop trying to pump data into the UI but rather just show the data source actor's front panel in a sub-panel on the UI.
(2,995 Views)
