Actor Framework Discussions
Questions about AF , QMH, StateMachines
If you understood Olli's post he's basically saying that the state pattern changes the actor object in the shift register (as you transition one state to another).  That is what provides the dynamic dispatch which replaces the old conditional logic.  The response to any given message depends on what state the actor is in (ie. which child class is loaded into the shift register).
Hopefully that is clear.  It sounds like that is what you want to do.  You can certainly use a helper loop, but I think the state pattern actor is a more elegant solution if you can wrap your head around it.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 11 of 14
(1,430 Views)
yes, I got state pattern, I downloaded and will try to use it.
I am trying to use also other "application" of AF, for example to make a publish-subscribe and "central actor", where the hierarchy is kinda broken (you end up passing around the enqueuers).
Message 12 of 14
(1,427 Views)
To be more exact: there is no shift register.
You have an Actor representing an abstract state (Context Actor). The concrete states are child classes of this Actor. So each time, you change states, Actor Core.vi of the current state object is kinda ripped out and replaced by Actor Core.vi of the new state.
Message 13 of 14
(1,424 Views)
WOW
I found so valuable pptx and videos on the NI WEEK 2018 section
go here
https://learn.ni.com/center-of-excellence
so much value
Message 14 of 14
(1,412 Views)
