Actor Framework Discussions
Reentrancy fork: working with an event structure on Actor Core.vi
AristosQueue wrote:
fabric: There's no need to create a custom version of the AF to do that. Just select the block diagram contents of your Actor Core other than the Call Parent Node itself and do "Create SubVI". Then make the subVI non-reentrant.
Yes... But that doesn't really work when those block diagram contents are an Event Structure, right? That is the example I was describing. Am I missing something?
AristosQueue wrote:
Having said that, David's problem is with the message handling VIs, not with the Actor Core override VIs.
Yeah sorry David! Didn't mean for this to turn into a hijack... 🙂
(4,137 Views)
Luckily, we can fix the hijack. 🙂
If you're using dynamic event registration, then, yes, it does work.
If you're using all static event registration for front panel controls, I would put those controls on the panel of the new non-reentrant subVI and make that the panel that I open instead of Actor Core.vi itself.
(3,283 Views)
