Actor Framework Discussions
Refactoring a project into Actor Framework
I notice the same thing, very frustrating
Message 11 of 18
(1,942 Views)
The default location is fixed for messages created by the Message Maker.  The project provider saves them to a different location (also fixed).
The project provider creates a folder for your actor, a subfolder for the actor's actual class, and then a subfolder for message classes (each in its own folder).  So the actor MyActor would have the following directory structure:
..\MyActor (containing MyActor.lvlib)
..\MyActor\MyActor (containing MyActor.lvclass)
..\MyActor\MyActor Messages
..\MyActor\MyActor Messages\SomeMethod Msg (containing SomeMethod Msg.lvclass)
etc.
Message 12 of 18
(1,942 Views)
Okay - actually makes sense now when the .lvlib file is considered. Up to now I've only been playing around with skeleton/prototype programs without commiting anything to a library.
Message 13 of 18
(1,942 Views)
The VIs that make up the message maker do not have passwords, so if you want to tweak the tools to be more to your liking, go for it.
Message 14 of 18
(1,942 Views)
*Most* of the VIs do not have passwords.  A few access restricted functions.  But if you are just looking to change destination folders, you should be OK.
Message 15 of 18
(1,942 Views)
ok I have a question, my LabVIEW 2014 doesnt put the little envelope icons on the message folders, it looks just like a folder. Is this a setting or something in the development environment?
Message 16 of 18
(1,942 Views)
I think that this is something that GDS does automatically to folders named Messages. If you don't have GDS installed for 2014, it could explain why you don't see it.
I never looked into how GDS does this, but I assume it's part of the project provider API.
___________________
Try to take over the world!
Message 17 of 18
(1,942 Views)
Thanks, that was it.
Message 18 of 18
(1,942 Views)
