Actor Framework Discussions
Scripting a reply message?
Hi Guys
Is there an easier way to script a reply message than the following? What I do today seems a bit tedious (using LabVIEW 2015).
What I do is the following:
1) Script a normal message to a method using the built in message maker
2) Change inheritance of the message to a reply message
3) Create a new VI for overwrite (Do Core)
4) Copy content of Do into Do Core.
5) Delete Do
6) Add output terminal to the send message VI and add the variant to data node with data type that match the method
Best Regards
Anders Rohde
Message 1 of 1
(4,117 Views)
