Actor Framework Discussions
Variant Attributes
Thank you drdjpowell and jon_mcbee for your advice, I appreciate the help. I now understand the power of variant attributes and how to utilize them.
Works like a charm now and I can address specific actors the way I need to in my application and do not have to worry about expansion in the future. I try to build everything with as generic of objects and fucntions as possible to allow for extendability.
Thanks again!
-Steven
(4,619 Views)
Generally that is a good idea, but remember that generality nearly always comes with a negative performance impact. Be aware of this as you're architecting. I'm glad you were able to find the flex you needed in this case.
(4,042 Views)
Thank you for the feedback and tip AQ.
-Steven
(4,042 Views)
