Actor Framework Discussions
Why Swap the Nested Actors in Stop Core.vi?
Hello AF community,
looking at the Stop Core.vi in Actor.lvclass, I wonder why the Swap Values function is used on the array of Nested Actors? Why not directly wire the unbundled wire and the empty array to the For Loop and bundling function, respectively?
Mat
(6,424 Views)
Mat,
just guessing... I still haven't upgraded
When swapping the array you make sure that the nested Actors are stopped in the opposite order as they have been launched... so last launched is being sent Stop first.
(5,238 Views)
Accepted by topic author Matjö
Oli: No. Swap Values does not affect the values inside the array.
Mat: It is my style. To me, it makes it clearer what my intent is. I'm taking the array away from the object that is carrying it and replacing it with an empty array. There are times when Swap Values provides a clear signal to the LabVIEW compiler of the programmer's intent that lets it do better optimization -- I am pretty sure this is NOT one of those cases. This is just me coding in a way that documents the model that is in my head.
(5,238 Views)
Thank you, that makes sense to me now.
Can the presence of the Swap Values fonction actually degrade the compiler's efficiency?
Mat
(5,238 Views)
Sorry, mixed something up there
(5,238 Views)
Only if there's a bug in the compiler, but then, that's true of any bit of code. 🙂 Assuming we have our compiler code right, expressing a swap operation using a Swap Values should always improve the efficiency or leave it unchanged.
(5,238 Views)
