This is the Actor Framework as presented at NI Week 2011. Since the framework was released at NI Week 2010, we are calling this version 2.0. If further edits are recommended by the community, other documents will be uploaded with later version numbers.
This version is saved in LV 2011. It does use one feature that did not exist in LV 2010 and will break if we do a "save for previous." The earlier 2010 version can be found here. There is a small bug in the 2010 version that was released -- Message.lvclass:Do.vi should be marked as Reentrant -- Share Clones to avoid unneeded thread synchronization. If you download the old version, make sure you make that edit.
[LATER] Version 2.0.1 is now available HERE.
We recommend installing the Actor Framework in user.lib\_Frameworks\Actor Framework.
I do not have LabVIEW 2011 installed. Where can I get a 2010 version?
Nevermind, found it.
