Currently the entire realtime sequence must be set to stop execution on fail or not. It would be better to allow each realtime sequence call the ability to generate an error message on fail and then allow the user to define if the appropriate action would be to notify only and continue, notify and give option to continue or abort, or to abort on fail and notify.
