Please modify the VIs from the NI-CAN Frame API library in order to use the 4x2x2x4 connector (pattern 4815) or at least a symmetrical connector.
The improved library would avoid wire bends (error cluster, ObjHandle...) and simplify the alignment of the VIs.
For example this is the current connector of ncReadObjMult.vi :
