Hello all,
In MAX, you can create a task or virtual channel for DIO
and the default setting is that MAX create one channel for one line
One of our customer ask if there is any method create a task of one channel for mutiple line
but in MAX, you can't set this
The only method for doing this is config it in LabVIEW code
It would be nice if this can be set in MAX
