It would be very good if the DSC llb will be reentrant (vi property -> shared clone reentrant execution).
It's no problem if I work with 50 citadel databases in parallel from executable files. But if I do it from one exe (with reentrant VI that work with citadel) then it works very slowly and very often with critical memory errors... And 50 exe files is not a good solution any way.
